4850 question
jybgess
Im going to buy a computer in about 30-40 days from AVA. I dont know much about computer stuff so here is my question. Will the heat issue with the 4850 cards be resolved soon? I dont have the no-how to replace the cooling fan on a card. thankyou
Its already fixed, sort of. You can manually edit a file (extremely easy to do) and increase the fan speed. I did this to mine and it took nearly 30C off my temps and the card sounds nearly identical to before.
http://www.hardforum.com/showthread.php?t=1320351
I'm sure it won't be long until its officially fixed, but until then this works.
