4850 or 4870
uB3rn00b3r
Ok I am looking at getting a new video card. My mother board is a Intel® 975X Chipset.
http://www.intel.com/Products/Desktop/Chipsets/975X/975X-overview.htm
My monitor is a 22 inch samsung.
I do primarily most of my gaming on my PS3 and was wondering if I should buy a 4870 with 1 gig off tiger direct for about $190 with cashback. Or should i save some money and buy a 4850 1gig off of newegg for about $150 with a discount code.
Should i spend the extra money on the 4870 or just buy the 4850 and crossfire it later if i need it because by that time the price will go down?
This is the 4850 i was looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102759
This is the 4870 i was looking at:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4037096&sku=D10-4874
For $40 difference get the 4870. Thats a terrific card especially at 1680x1050
The 4870 is definitely worth that price. It's a great card, and you'll be able to run pretty much everything maxed out on your monitor.
When the 4800-series launched and the 4870 was $299 while the 4850 was <$199, the 4850 was the better choice for budget gamers. Now that the 4870 appears to be under $200 in the states, it doesn't make much sense to buy a 4850 unless you can find it for $130 or below...
For that monitor, get a 4870. It will have plenty of power for a 1680x1050 monitor for at least a year if not more.
Also to note, I have 4850 crossfire and the new 8.11 drivers won't work... so I'd go with the single card solution just for the ease.
Ok. I will probably go with the 4870 then. Also I am assuming that it will work with my motherboard? And can someone tell me how the Cashback thing works. I think its 15% and the deals over tomorrow.
Also is that 15% taken off the original price or the price with the rebate taken out?
