I am running Windows 7 on a 19'' at 1440x990. I recently upgraded to Windows 7 and put 9.11 on it. Now I have some graphics issues in borderlands (some walls don't render) and I figured it might be best to reinstall my driver. So I went to uninstall it and it did not seem to work. It uninstalled the install manager and left the graphics driver still there. Now I looked up what to do and the consensus seems to be to use driver cleaner or another program to clean it out. Little worried about doing that and wanted to see what you guys thought So:
1) Would the non-rendering be a problem with the display driver or Borderlands? Should I reinstall it? I have only played that so far so I do not know whether it is only that game with display issues..
2) Anyone have any experience with uninstalling in 7 and get a similar problem. What did you do for it?
