4850 Crossfire Question
I have a 4850 512mb crossfire setup in my desktop, and I was wondering if there is a way to make the fans on those two cards go to 100% speed when I run Starcraft 2, and any other time the fans would just be on "auto". Is there a way to do this without opening and manually setting the ATI Control Center to those setting every time I start up and then close Starcraft ?
Thanks.
set up a profile to run the fan at 100% when you launch SC2 in the ati CC
easy as that
I'm looking in the profile manger, but im not sure i understand it very well, would you happen to know where a step by step guide / tutorial is ?
Thanks man
I think your best bet would be to use a program such as MSI Afterburner (works with all cards not just MSI cards) which will allow you to set a custom fan profile. You can set it to keep your card nice and quiet at idle and automatically scale the fan to 100% once the temps go up pretty much at all.
