christpunchersg
- Feb 14, 2008
Anyone out there with a 2x4850 in crossfire config? Is there any microstuttering with two of these cards at the moment?
I am thinking about crossfire 4850 as well if i can get them for $150 or so but my psu only has 2 pcie plugs. For you sli and crossfire folks out there how do you do crossfire if you need 4 pcie plugs and your psu only has 2? Is it ok to use 1 molex to pcie adapter and 1 native pcie plug on each card? My psu is a 700w ocz gamexstream.
One 4850 now, another one later when you feel you need a lot more performance or want to make it last longer. The next generation of ATI GPUs should be farther away than the 3k-4k step right? I don't expect them to last me as long as my 9800 Pro did but..
