Jun 24, 2009 #1 D darkz179 Limp Gawd Joined Oct 23, 2007 Messages 507 topic^^ i am running a 460w 12v @ 24a can i power it?
Jun 24, 2009 #2 S shadow_419 Gawd Joined Apr 10, 2006 Messages 602 12V x 24A = 288W max 12V power Typical system power consumption with a 4850 @ load is about 200-250w. I wouldn't do it, but it's up to you.
Jun 24, 2009 #3 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Since you're running a dual-core at stock speeds, you'll be alright providing your PSU is actually decent.
Jun 24, 2009 #4 D darkz179 Limp Gawd Joined Oct 23, 2007 Messages 507 dynapower 460w its a 1u server psu, so it should be more robust than most desktop psu's
Jun 25, 2009 #5 J JoeBob Limp Gawd Joined Jan 8, 2007 Messages 391 As mentioned in your other thread, the HD4850 isn't that much more power hungry. It should work, if it doesn't, you'll know. But I'd wager it would work.
