4850-4870 owners excel help
M1ster_R0gers
[H]ard [H]eaded
long story short
Here are links for an excel spreadsheet charting macro for these cards. I would like some help getting it working better. It monitors on board sensors with regards to usage and temperature.
instructions:
1. open gpu-z and click on the sensor tab. enable the log to file checkbox. this file MUST be saved under c:/temp directory. Leave gpuz running.
2. play 5 mins of your favorite game.
3. open the excel macro enabled worksheet. click on the macro that says gpuz_xls_conversion. Things should happen. allow read only access (that should happen if gpuz is running.) Then click on the chartmaker macro.
gpu-z download http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
excel spreadsheet http://churchel.com/hardocp/
Thanks anyone for helping. I will be out for a few hours, any feedback is welcome.
Look at the gpu usage chart in comparison with different games and apps. They all seem to have a different impact.
Gpu-z adds to the existing log file so you can have a single chart with several applications tested. It creates about 1MB an hour (est) and excel can handle somewhere upwards of 15 mb of logs from this application.
Have fun!
here is a futuremark 3dmark06 run
edit: here is the same run with 4xAA 8xAF enabled. The FPS difference was 30 avg vs 70 avg.
edit:
here is Battlefield2 gulf of oman in AA comparisons:
