4850 1gig = 4870 512mb?
no, they are not equal, DDR5 has definite advantage over DDR3 counterparts. not to mention 4870 has significant higher clock vs 4850.
Which is better, a faster card that supports DX 10.1 or a slower card that supports DX11?
Depends where you put the stress, but I think the extra throughput of the HD4870 will manifest itself in the form of a performance bump more often then the extra ram (especially on that ~70GB/s mem bus) of the HD4850.
Definitely a faster card that supports DX 10.1. The first run of DX11 cards will be just like the first run of DX10 cards... not really fast enough to make it worth it to use the new features.
If I remember right, DX11 is designed to support dx10 and dx10.1 hardware. I'm not sure what the difference will be from DX11 hardware, but that's what all the press releases say.
your calling the 8800GTS and 8800GTX "not really fast enough"?
4850 doesn't benefit from 1 gig of ram in games. It's more of an e-peen thing.
