4820K would be better than 4770K for multi GPU- multi monitor setups.. Due to more PCI-E lanes and better RAM, but also have lid soldered and not glued.. Wich its better for cooling purposes, and it suposse to allow better OC ability than 4770K..
It will be interesting to see as more info comes out on the overclocking (only saw one, I think hardware canucks had their 4820k at 4.85). At default, the 4770k pretty much edged the 4820k out on all most every test.
It seems like the 4770k beats out the 4930k on a lot of tests as well.
I'd quote someone:I noticed the 4820K is cheaper than the 4770K. curious why it's cheaper. spec wise it seems to be a slightly better processor.
Now imagine Intel wouldn't give us discount for CPUs. In addition Ivy-E is between 4670K and 4770K, and for its full potential needs quad channel RAM. Well Intel increased MSRP for Ivy-E, even when Ivy-E is (obviously) not as great overclocker as Sandy-E. So for overclocking they are about the same, for nonoverclocking user, HW is faster. (and 1050 has great CHEAP boards with a lot of USB3.0 and SATA III ports) There is no reason why would Intel price older architecture with less ports higher than newer one.Do you folks pay 400 $ for a motherboard? You gotta be kidding.
It does not have better RAM. Quad channel may net your more bandwidth but it comes at a price in latency. If you are the sort of (non power user) who just games, than it's a downgrade for you. If you are an actual power user than you wouldn't be caught dead playing games on your box and wouldn't need to ask about this.
The server and workstation improvements aren't for people who post on hardocp, they're for actual power users. You might as well be telling people to buy quadro cards.
I'd quote someone:
I wanna quad core Ivy-E because the 2011 socket is more robust and heavy air coolers would cause less strain for the motherboard.
I just went through deciding which to get, and got a 4820K and X79-UD3 under $400 total.
For $400 that is a great deal. Did you get the newer 1.1v mb? Where did you score such a hot deal?
I have 2 HD7950s and I was thinking about getting the same CPU+MB combo yesterday. Seems like a good set up for Xfire.
