Dave-Mastor
- Nov 11, 2009
Hello all. I have a quick question:
I'm building a water cooled computer with, and I can't decide on what components to get.
I figured that I'd have an all internal system, I don't like the looks of having the radiators mounted on the outside of the case, and it might be a hazard due to the computers location. I'm going to get a Silverstone tj07 case, which has enough room on the bottom for a 480mm radiator. Now I'm going to have a Core i7 processor overclocked as much as I can safely do, and probably have dual SLI of the newer nVidia GTX300 series after release in a few months.
I want to know if I should have a single 480mm quad radiator and all the components on the same loop, or if I should have two 240mm dual radiators and two loops. Or something else?
Also, could someone recommend a good pump and reservoir, or fans for this operation, that would be really awesome!
Thanks.
Thanks.
