Mar 29, 2010 #1 F f3nix n00b Joined Jul 6, 2007 Messages 57 I have a corsair 1000w hx psu. Will that be enough to power an sli setup with 480gtx's?
Mar 29, 2010 #2 SeaFoam Supreme [H]ardness Joined Oct 13, 2004 Messages 5,066 Just make sure the flux capacitor has enough fluid and you should be OK. Seriously though, it should run it fine - I would be more concerned with cooling.
Mar 29, 2010 #3 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 Yes, the HX1000 is enough to run a GTX480 SLI setup.
Mar 29, 2010 #4 H heatlesssun Extremely [H] Joined Nov 5, 2005 Messages 44,154 I plan on putting two in my sig rig and upgrading pluging in my i7-980x and my calculations are that I'll be fine with my current 1k PSU.
Mar 29, 2010 #5 R RamonGTP Supreme [H]ardness Joined Nov 9, 2005 Messages 8,149 I think jsut about every review has power consumption figures and they're all around the mid 600watt range for a 480SLI setup. So yeah, 1kw will be plenty, even if you have sevearl more drives and fans than the test beds do.
