infinity4life
- Dec 23, 2005
I'm stumped here. Just got my 4800+ today.
Iv'e got a Thermaltake Tsnami Dream case (w/ 6case fans), a slot cooler for my SLI'd 7800GTX's, and for CPU cooling using a Zalman cnps7700
REgardless of if I use the Zalman or the stock cooling solution, I can't overclock it - even from the default 200 HTT/FSB/whatever you want to call it, anymore than 205 and I am hard-locked out of windows. If I use Asus's o/c (called standard o/c), once again I can't get it to boot into windows if I use a value that goes above 205. If I use Asus's NOS option, if i set it to go above 205 once again I can't get into windows.
I'm afraid to touch the vcore because I can't figure out how I can't even get a 5% o/c out of my system....I can't even boot into fricken windows, let alone run stress tests!!!
Fyi, it's a 4800+, air cooling (see above for description), corsair pc4000, Asus a8n-sli premium
Heat isn't an issue (@ stock specs, under load it stays around 40deg. for CPU), voltage isn't an issue (from the PSU, it's 550watt sli-certified enermax), so I can't figure out why it REFUSES to boot into windows for a HTT above 205??????
