4800+ on chip memory controller problem
tompson
this is long... but bare with me.
ok, so I want lots of memory bandwidth (3DMark05 LOVES the bandwidth) so I'm running my CPU at 10x multiplier and I want to find my highest FSB / HTT overclock at this speed. So I seem to be hitting this limit of 264MHz which seems ok. Prime95 is stable for 6+ hours with two threads of it running simultaneously. However, Memtest fails!
So my first guess is that it's a memory problem. So I lower my multiplier to 8x and up my memory voltage to 3.5V... No good. So I eventually raise my CPU from 1.40 to 1.475 volts (big jump) and all of a sudden memtest is stable. Not a memory problem but a CPU problem? This doesn't make much sence since a blend test in prime95 is ok AND I've run the CPU at faster speeds using higher multipliers. I've been able to get 2676 = 12 x 223 vs 2640 x 10. So my best guess is that the on chip memory controller must be failing at 264MHz HTT (ok at 263) while the rest of the CPU can go faster.
Is this normal? Has anyone else found that the on chip memory controller is the limiting factor in their overclock??
I thought that the ALU and the internal cache were the biggest problems at high speed.
This makes me believe that the new revision E mem-controllers aren't very good at overclocking.
__________________
my specs:
eVGA e-Geforce 7800 GTX KO video card
Enermax Noisetaker 600W
OCZ EL DDR PC-4000 Dual Channel Gold VX (voltage extreme)
AMD Athlon 64 X2 4800+ CPU
2 X Western Digital 8MB buffer, 74GB Raptor in Raid 0 array
DFI LANParty nForce4 SLI-DR
Lian-Li PC-V1200 Plus case modified with window
Thermalright SI-120 CPU heatsink and Panaflo (Panasonic) 120mm M speed HydroWave fan
Dell UltraSharp 2405FPW 24-inch Wide Aspect Flat Panel
IBM Thinkvision L190 19" LCD Monitor
Sound Blaster X-Fi Fatal1ty FPS
Logitech Z-5500 digital 5:1 speaker system
yes and yes. i had a s754 3000+ that would do 2.6ghz, but any memory speed over about 222mhz the system spazzed(using pc4000). made me a lover of mem dividers.
the rev E chip i have now will do well over 250mhz mem now though(same pc4000), even if it wont stablize past 2.7ghz.
