48-bit addressing
RikuS
Hey does anyone know which mobo's support 48-bit addressing so I can use a larger than 137gb had drive without a add on card? Windows xp sp1 had it enabled by default after you install it, but it also throws back to the mobo manufacturer if they support it in the bios. If anyone can help, I'd appreciate it!
-Rikus
RikuS
Strike that, I saw the nice post in data storage for this subject! Apparently I am blind!
-Rikus
