I have noticed many odd things with the temperature of my 4790k. The cooler is a Corsair H110 and mobo is Gigabyte Z97X-UD3H (F4). It idles between 25-30c, and doing anything from loading a website to resizing a window almost instantly increases the temperature by about 15c until it's done, then instantly drops back down to its idle temperature. Medium-heavy use of the CPU resullts in around 50-60c temps, and prime95 causes it to hit 80c.
Maybe if I was using a stock cooler this wouldn't be too shocking, or maybe if the idle temp of the CPU wasn't so low to suggest there was a problem with it, but that's not the case. Is this normal?
Gif of the resizing temp issue: http://puu.sh/djd7m/d1878a8b5f.gif -- I seriously doubt resizing a window is that intensive. What's going on?
