Bluesun311
- Sep 21, 2013
Sounds about right. My delid job is real half assed. Just using nt-h1 on the die and then more paste between ihs and coldplate of the smallest AIO you can get. Still made a massive difference.
The x264 test you posted uses 100% of the CPU while encoding, and at decent temps.
It's actually pretty good so far... It did force me to lower my Ring multi down to 45X. I'm sure I've got more tweaking to do, but you can tell when a chip is stable at a given frequency, even if you might need to add a little voltage to get it passed something nasty like p95. If you are having trouble even getting into windows, that's not good. But when everything works fine, you are getting good benchmarks, and only p95 or x264 brings you down, you are close to full stable.
Got my 4790K from MC. It's a L419B538, and I thought I lucked out. My case was out of stock (Corsair 550D), so I tried the stock cooler just to see how it did. Fail! Hits 100C at 4.3Ghz and throttles running Rosetta@Home (Boinc). My i7-860 overclocked ran that for years 24/7. I do have a H110 for it, but it will not fit in the new case like Corsair said it would. Not happy.
some need to be delidded to run normal temps stock.
I call BS on this.
Do you have a link?
A link to my personal findings? Here: link. I started out with a 4770S that would throttle itself in AIDA64 @ 3.9Ghz. Dropped in a 4770k directly after and it didn't have thermal problems like that. It was stuck at 4.2Ghz. I've tested a lot of Haswells. 10 now, counting that S chip.
Sometimes the gap between IHS and die is larger than others. This isn't rocket science.
You're suggesting that the reference design hits thermal throttles while in its designed operating spec... is that right?
How much of a hassle is it to do bare die?
If the IHS isn't making good contact with the die... Yes. And Intel promptly replaced my throttling 4770S with a retail packaged one. Which I dumped on eBay.
The overclocking potential of the chips has nothing to do with their thermal characteristics, but both vary widely on the Haswell. In my admittedly very limited experience some chips are just hotter than others but that one did throttle at stock speed. With a Hyper 212+. Multiple seatings all similar temps.
I bought a 4770k to replace it with and it would hit 85C on the same setup on the same day at 4.2Ghz in AIDA64. Big difference.
They can't be binning the chips on anything but other than where they are on the disk, or whatever you call the silicon thing they stamp them out of all at once, right? Not like they test them do they? I have no idea about the binning process. But I test chips like a monkey so I can give you some observations. If I were in a different tax bracket I would be messing with X79 right now, but I'll wait for Haswell-E.
So the 4770 and 4770k both boost to 3.9ghz and the 4790 does 4.0 but the k will boost to 4.5ghz? Sounds weird. And unlikely.
Also pretty sure the rumors that DC will only work on z97 are not rumors.
Wow this shit get's reaaaaaaly hot.
I delidded mine and it dropped 25 degrees at 4.7Ghz with Large FFTs in Prime. Then I started working with Prime95 v28.5 small FFTs at 4.8Ghz/46x cache. 1.3v Core 1.25v Cache. It hit 100C pretty much right away like that... but it didn't crash, I'll just quit pushing this chip until my loop is finished
Devil's Canyon + tiny AIO cooler not good mix.
If I had to guess, this chip is 4.8Ghz stable.
Not dead guys. Appreciate all the activity in this thread. Been working on family fun this summer. Disappointed with haswell overall.
Tried to watch video but no go using the link posted, Any help ???
I call BS on this.
Do you have a link?
