Did the Asus 5 way tune and it came up with 4.9ghz @ 1.375V... I thought it was best to keep these under 1.3v? I decided to try and drop down to 4.8ghz and so far I keep dropping the voltage in the AISuite (at 1.25V) and the voltage seen by Coretemp wont drop below 1.31V which appears to be AIDA64 stable. I was told Prime 95 is a bad idea for Haswell chips.. is AIDA64 the only stress test I should use to confirm stability? Right now on AIR with a silent build I am pushing my limitations due to heat.
