Justintoxicated
- Apr 10, 2002
so a few years ago when I built my rig I I got everything up and running pretty stable. Last few days I have been having some issues though.
clock_watchdog_errors. when doing something as simple as opening google chrome.
Then problems even booting up..
I removed the overclock and loaded optimized defaults and booted fine.
Loaded hardware monitor and turned on prime95 small ffts (it was the version optimized for the 4770k I believe.
Anyway the temps shot from mid 30's up to 95-100c immediately! So what could be going on? I don't beleive this is normal but i did build the PC some years ago.
I have 2 quad 120 radiators and a direct die water cooling block (delidded CPU) in a 900D. I used a liquid metal tim on the cpu die. Guess it's time to remove the block or else maybe the temperatures are just wrong?
Thank in advance.
Thank in advance.
