4770 crossfire on IP35-Pro?
colinstu
Being P35, it says one PCIe x16 slot is running at x16, and the other at x4. Is it possible to run as both 8x?
A single 4770 runs "meh" better then what I currently have, but if I could xfire two of them... then I'd be running near the speeds of those really high end cards.
How is micro stuttering. anyone notice? Is it really that annoying?
No, that P35, like most, can't do 8x-8x. You'll be stuck with 16x-4x. You can still Crossfire the two cards, but I'm not really sure how that works out with one probably being slower than the other (assuming the 4770 probably needs more than 4x).
If you're looking for a upgrade get something like a GTX 260 or 4870. You won't get much done with crossfire on that board.
