Use QuickSync if you can, that will take DVD encoding through the roof. Usually 2-3x whatever the CPU can muster. Although Handbrake has an issue with QuickSync on the 4xxxx series.
I thought the same thing. But after playing around with NVENC I am totally happy with it. You may not be able to get the same size/quality ratio. But after doing a lot ofQuickSync while it looks better than NVEC and AMD VCE, still looks worse than CPU only.
I would never use GPU Encoding in its current state for my personal MP4 MKV library... But that's just me
If size isn't a concern, then use Quicksync i guess.
