4600+and DFI lanparty need help
om3gad3a7h
alright i need some help im debateing on gtting at 4600+ X2 and a DFI LanParty NF4 Sli-DR Expert motherboard now i can get them both for 387 shipped sound good or bad need advice
or should i go with a ASUS M2N-SLI DELUXE AM2 MB and a AMD 3800+ X2 combo for $295.95 shipped
do you plan on using your ddr400 ram? if so, you'll need the 939 combo, though, you don't really need the mobo, just the cpu ($246). btw, the 3800+ x2 is only $152. if you are going to buy or already have ddr2 ram, then go with core2duo instead of am2. the cheapest core2duo will outperform the 4600+ at stock speeds, and it only gets better if you're overclocking. E6300+GA-965P-DS3=$340+tax/shipping. if you need/want ddr2 cuz core2duo is too sexy and u want one, then get the curcial 2gb for only $200AR.
filthysanchez said:
if you're buying a new AMD mobo/cpu, you might as well go AM2.
Unless you don't have money for DDR2 and plan to use your DDR ram, lol.
Don't buy it now if you're not going to use it. Buy it later, when more choices are out for mobos and prices have settled down a bit.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80061-9
Crucial Technology Ballistix BL2KIT12864AA804 2GB kit DDR2-800 PC2-6400 Memory Retail
Manufacturer: CRUCIAL TECHNOLOGY
Manufacturer SKU: BL2KIT12864AA804
Our Price: $239.99
Mail-In Rebate: $40.00 Expires 09/24/06
After Rebate: $199.99
