450$ to rebuild computer.
Heyas folks my ancient socket 939 ASUS mobo just bit the dust after a power surge blew the PSU. I have 400 dollars US to swap out the core components of the pc. I would prefer to stick with AMD and to go with an AM3 build but I'm willing to work with P55 core i3.
1) What will you be doing with this PC?
CausualCore Gaming, Web Browsing and mild Video Encoding
450$ with 50$ overflow for shipping, tax and what not.
3) Where do you live?
Toledo, Ohio but would prefer to order online.
4) What exact parts do you need for that budget?
Need a mobo, 4gigs of ram, CPU, and PSU
5) If reusing any parts, what parts will you be reusing?
ATX Case, DVD drvies, Hard Drives, 9800 GTX+ .
6) Will you be overclocking?
Lightly, defiantly nothing extreme.
1680 x 1050 20 inch monitor.
Within the next 3 weeks.
9) What features do you need in a motherboard?
I wouldn't mind a mobo with USB 3.0 support like this AM3 or this P55 but it's not really important. Doubt I'll need SLI or Xfire support. Basically just need something with decent oc'ing ability.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
Intel Core i3-530 Clarkdale 2.93GHz LGA 1156 73W Dual-Core Desktop Processor Model BX80616I3530 - Retail $124.99 free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222
EVGA 123-CD-E635-KR LGA 1156 Intel H55 ATX Intel Motherboard - Retail $159 $20 mib $139.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188062
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL8D-4GBHK - Retail $94.99 $5.99 shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231180
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail $99.99 $10 mib $89.99 free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
i will do a amd build as well
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail $165.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
GIGABYTE GA-MA790XT-UD4P AM3 DDR3 AMD 790X ATX AMD Motherboard - Retail $114.99 $15 mib $99.99 6.98 shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128378
i would say if you wanna go amd this would be the build
My recommendations
Asus M4A77TD AM3 $79.99
Corsair CMPSU-650TX $99.99
OCZ Gold Edition 2x2GB DDR3 1066 $79.99
Phenom II x4 965 Black Edition 199.99
Comes out to a little above your 450, but there are 2 $10 MIRs, and the shipping would only be 10 dollars.
gwarren's build is very very solid
you might want the ripjaws instead of those corsairs for a buck more
