kent
- Apr 8, 2001
I just dropped an eBay 4400+ X2 in my 939 machine in the rig in my sig.
I forget the stepping, but it was manufactured the 38th week of 2005, I believe. (0538?) Also this processor is the ADA Toledo core (110w TDP versus 89w TDP, I believe)
It's stable but it seems to be getting too hot.
Settings:
Multi: 10.5
HTT: 248
CPU: 2605MHz
RAM: 201MHz (402MHz effective)
Voltage: 1.45 (actual is 1.46-1.49)
I chose 1.45v because Windows would not finish loading with 1.425 or 1.400.
Anyways, BIOS idles around 32C, as does Windows. Matter of a fact -- it's showing 28C right now.
As soon as I start Orthos (5 seconds later?) the CPU temp JUMPS to 55-65C and CoreTemp shows the same thing. How can a processor idle below 30C and 5 seconds under load causes the temp to double?
I applied the processor with a THIN COAT of AS5 all over the IHS. By thin coat I mean I dropped two drops of AS5 in the middle and kept spreading until the entire processor was covered with a thin coat.
What's going on here? BTW my case has 2 120mm fans and all my wires are neatly tucked and hidden.
Settings:
Multi: 10.5
HTT: 248
CPU: 2605MHz
