Well, its $60 more expensive, and all it has is a 9x multiplier. with my current mobo, I can really only go up to 245, which would make that opty sit at 2.2GHz, not worth $310, when I can get 2.2GHz and 2x1MB cache with a 4400+ stock! Then 245x11 is 2695 MHz...not too shabby.holli4pirating said:Are Opty's out of the question for you two? They're the best OCer's and the 165 is pretty cheap, considering a good one can do FX60 speeds.
once again, the 4400+ will do the same speed for $250. That would be the chip I would buy if it werent soo expensive!holli4pirating said:I see. Well if you're limited on OC by the mobo, what about the 4800 at monarch for $355
as i said, there is almost no data out there on a 4600+. They just seem to be unpopular compared to teh 4400+. Im sure that now that the price dropped, we will see them more freequently, but at this point their OCability remains to be seen.Chilly said:no one has answered my question, which will overclock and perform more? like will the 4400 get to 2.6 before giving up, and the 4600 up to 2.8, or vice versa?
oh yea, all the X2's have dropped. You can get a 393 3800+ X2 for $150!! Thats what I paid for my 3000+ a little more than a year ago!!holli4pirating said:Oh wow, I hadn't realized that the 4400 was so much less. I didn't see that it's price had dropped so much.
i'd personally stop at 1.55v (im on air), but 1.6 isnt that unreasonable, especially for H2O.turtletrax said:my 4400+ does 2.8Ghz at 1.6Vcore and tops out at 2.86Ghz with 1.65Vcore.
Seems like it would do about 2.75Ghz on air with acceptable Vcore. Never really tried.
And for those of you that think that the Vcore is too high I havent run this chip under 1.6Vcore in over a year. I got it in june of last year and ran it hard since then. Looks like the 90nm process isnt as damaged my Vcore as most thought.
HighwayAssassins said:(eclipse forgive me for the hotlink, i figgured you wouldnt mind since it came right out of the A64 OC data thread)
you got some time.(cf)Eclipse said:
i'm gonna have to start working on a layout for a revG oc'ing thread
That certainly is an enticing prices even for us cheap bastardsHighwayAssassins said:once again, the 4400+ will do the same speed for $250. That would be the chip I would buy if it werent soo expensive!
