4400 Dual
SDNYC09
Real fast question about the 4400 dual core , and raid.
4400 dual core @ 2.4 10x240 ht x4
gigabyte K8N Pro SLI
mushkin black line
2 7800 gt's SLI
2 74gig raptors - raid 0
no problems at all overclocked nice no hickups at all with zaleman full copper heat sink temps are good, i was wondering about a 3dmark score i got. I used to have a amd64 3500 with the same setup and i notced the troll scene with the chick with the sword during the cpu test frame rates dropped to liek 5-7 when they start fighting, i use this point cause its the only rates id remeber cause id get so pissed they dropped so low. after changing to the the 4400 overclocked to 4800 speeds, which i tested with sandra 07 that im actually running faster then sandras marks for a 4800+ the frame rates at that same scene are the same, it drops down to 5-7 maybe 10, i dont understand. i was thinking maybe 3dmark 03 dont support dual, but i didnt see anything on that. i used 3dmark03 cause its all i rem in rates to see if there an impovement. this was my scores
3dmark03-26478
3dmark05-11640
arent these kinda low?
cant even run 3dmark 06 soon as it hit the cpu tests drops to 0 - 1 frames takes forever to finsh.
One last question about the raptors, im using RAPTEST and the write speed is like 145 but the read speed is always no higher then 60 on a fresh install of windows, latest nvidia drivers. really pissing me off, any help would be great, thank you for your time.
