4300 Overclock - memory choices
cerebrex
I've been browsing around trying to find what would be a cheap solution, but something that won't prove to be a paperweight when I switch motherboards. I went in on the fry's 4300 sale for 149.99 w/ the ECS doorstop mobo and i picked up a zalman 9700... I wanted to toss in some decent memory that I could take with me to an asus board to overclock with... I'm on a budget. I was originally looking at 1GB DDR2-667MHz.. however I ran across a similarly priced 2GB setup...
What is your opinion of OCZ S.O.E memory? Looks like it has pretty rave reviews and it's pretty damn inexpensive! I planned on just a 7600GT and I hope it will run faster than my previous 2.4C @ 3.30GHz system... but it's hard to find any solid evidence how it will compare since its a dated system.. however my 2.4C got a 4.3 score in Vista.. better than some of my friends with E6700 conroe systems?
I went with the lowest price G.Skill 2Gb kit from Newegg and my 4300 is sitting at 3.2Ghz with room to spare.
http://www.newegg.com/Product/Product.asp?Item=N82E16820231098
169.99 is a little out of my price range.. and I've been told many times DDR2-800 is a little bit overkill for a E4300 overclock, as most of the decent 4-4-4-14 mem's will easily make 800+
I suppose I should have specified I'm looking at 2GB kits of DDR2-667
I decided to get a higher end video card and I'm balancing out with less mem. I've temporarily decided on this memory:
http://www.newegg.com/Product/Product.asp?item=N82E16820141210
it has good ratings and looks pretty popular. I just want to make sure when I buy another 3 sticks, it will all work well in dual channel... anyone have any experience with any timing differences in pqi brands? I don't want to run into any issues.
I got the same at frys and I got the cheapie ram along with it. Paid $160 for 2gb ddr2 667.
It as called "transcend jetram" and the only place I've ever seen it is my frys.
Edit - PQI, afaik, is known as "bottom of the barrel" ram. Buyer beware.
okay, PQi sucks everywhere then.. I'm into photography and their CF cards seriously suck.
Rurki, which MB are you using, and what voltage do you have that G.Skill set at? Am using a similar setup and have had a hard time with voltages. You using an FSB of 355?
Running the Asus P5N-E SLI at 1.46v
The FSB is at 356, however I have the memory unlinked and running at 820 5-5-5-15
