430 antec truepower + 6800u
saark
----> Primary connector on 6800ultra
-------> empty
-------> empty
----> Secondary connector on 6800ultra
-------> dvd writer
-------> empty
-----> sata connection to harddrive (cannot use on 6800u)
is this the most efficient setup for my setup? i'm getting a lot of stability issues with my 6800 ultra and im thinking its the power supply. should i junk it and go for a larger size with 3 individual strings so that each connector into the 6800ultra is solo?
thanks
good question ,id like to know this as well
do you have +20 AMp on your 12 v line?
sniperchicken said:
Your psu manufacturers website would probably tell you ;)
OUTPUT
+5V -5V +12V -12V +3.3V +5V
36A* 0.5A 20A* 1.0A 28.0A* 2.0A
shrug
I have the same PSU in my system and i have a feeling its holding me back. I ordered a PC Power & Cooling 510 which should arrive next week.
-------> empty
-------> empty
-------> dvd writer
-------> empty
thanks
Try underclocking the video card and see if it becomes stable.
Get a Fortron 500W or above power supply. Fortron is one of overclocker's top choice for PSUs in general. Even better they don't seem to carry the airborne virus known as a brandname so they're relatively inexpensive. I got mine for $60 at NewEgg. To give you an idea I have a 530W Fortron in my system and have been running the following off of it for the past month with no stability issues at all:
P4 3.2GHz @ 3.6 on Abit IC7-MAX3
2GB Kingston HyperX RAM
2x 74GB Raptor drives
BFG 6800 Ultra @ 435MHz
Sound Blaster Audigy 2 ZS Platinum
NEC DVD +/- RW
Floppy drive
Coolermaster Musketeer
Coolermaster Aerogate II
Coolermaster Jet4
4x 80mm fans
1x 60mm fan
1x 120mm fan
Honestly I could probably run my older rig off this thing in conjunction and I think I would be fine.
