423 to 478 adapter
ne0-reloaded
i gotta 423 p4 cpu and my motherboard just died. i need a new one, but the majority of 423 motherboards use RIMMs. ive seen some 423 to 478 adapters and was wondering if any can tell me if they work w/o any problems and do the maker of the adapter makes much of a difference.
thanks
Those adaptors are usually the other way around, they let you put a 478 CPU in a 423 motherboard.
You really would be better off getting a new CPU.. most (if not all) socket 423 P4's are williamettes.. Those are slower than current Celerons at the same MHZ.
==>Lazn
well it's the other way around for me. i have a 423cpu/mobo, but my mobo died. i need a new one, but i dont wanna go w/ rambus (wayyyy overpriced). thanks for the help tho. guess ill just buy a cheap intel board or somethin.
liquidtrance123 said:
another vote for a cheap mobo and a newer celeron, they'll probably perform about the same.
but that would cost more than just buying a 423 board tho. i saw a $50 intel board im gonna order. it was my dummy dc, so im kinda missin it right now.
