4200 oc
[teh]manwich
just did my first overclock last nite and i could only get my cpu stable at 2.63ghz with 1.4v. when i got to 2.7ghz with 1.425v i couldnt do a full run of superpi at 32m without errors. should i up the voltage more and see what happens? or is the voltage already too high? by the way, after the overclock, the cpu is 35c idle and 44c underload.
Give it 1.45 and see what happens. I would go up to 1.5 if needed, but keep an eye on your temps
yea if the temps get up to 50 im gonna back down a bit. but i just dont know what the limit is with the voltage. ill give it a try tonite and see if i can maybe get it to 2.75ghz.
If you are using a stock (all aluminum) HSF you will run into temp problems trying to go any higher. With a good cooler you can get to 2.7ghz on 1.5v (maybe less) and keep the temps below 50deg C.
Mines maxed at 2.68 right now and I did a lot of messing around. I found that with a multi of 10.5 I could be stable at this with it at 11 max is 2.62. FSB is 255. That's both memtest and orthos stable.
well im using a zalman 9500 cpu cooler so i dont think temperature problems will be that big of an issue. ill bump the volts up to 1.45 and try for 2.7 and run superpi.
well i set voltage to 1.5 and tried 2.7 and i couldnt even start superpi without errors. so the best i could do is 2.67 and thats about it. although i can leave the voltage at 1.45, and when it was at 1.5 my temps were a bit too high, so i guess 2.67 is the limit.
