42'' plasma w/ ATI AIW
kblazk
i was looking at getting a plasma hoping to keep cost under 3grand i found this NEC for like 2799 at some pricewatch site http://www.necvisualsystems.com/applicationFiles/productDetails/appl_productSpecs.cfm?Product_id=340
but the native resolution is so low 853x480 and i want to hook it to my AIW and creat a media center from my pc but will the text be really bad looking? I want to be able to read text from a resonable distance like 15ft and what resolution should i run at to acheive this the AIW supports 640x480 800x600 and 1024x7?? I donth think i will run any higher than that.
any thoughts would be greatly appreciated, i know that i should get a HDTV plasma to be safe but thats like 2 grand more.
what AIW is this? There will be a big difference between the AIW9800 and the AIW7000. I imagine you can get 1600x1200 if you are using the AIW9800.
Well, all i have to say is you get what you pay for. 853x480 is pretty much the same resolution as the tv you have now. Can you read the text on your tv you have now? I'm guessing not. Also, if you get an hdtv you can output via dvi if the tv has it. Therefore you wouldn't even need a AIW. If your biggest concern is having a tv that has a good picture at around $2800 then i would suggest a crt rear projection. Hitachi makes some really nice ones. The 65s500 is $2649.99 at cc right now. They also have a 51 and 57 in models for less. It will make that plasma look like total crap.
Of course if your biggest concern is having a flashy looking tv until you actually turn it on and realized what a pos it truly is, then getting a cheap plasma is what you need to do. Otherwise buy a rear projection crt or buy an expensive plasma/dlp/whatever. However, at your pricerange there is nothing better than rp crt.
I totally forgot that plasma's had DVI input, silly me. At any rate I agree with the guy that posted above this one. I would steer clear of cheap plasmas because not only do they look like shit, but they die fast. Actually, You might want to get a projector, those things are sweet and you can get them for under 3 grand.
I don't know which NEC you were looking at, but as far as TV usage is concerned NEC does have some decent plasmas. I've got a Panasonic Plasma (TH42PWD6UY) at home that I paid less than $3000 for and it has absolutely fantastic picture quality. Don't let the resolution fool you, it is awesome for DVDs, digital cable, and HD cable (or satellite) as well. At typical TV viewing distances the resolution doesn't matter as much. The contrast ratio, black level, color accuracy and color uniformity are great. I guarantee that you would be happy with it for TV or home theatre usage.
Computer use is a little different. Text will be perfectly readable just like it is on a 640x480 or 800x600 monitor- the plasma is a digital display not an analog so you don't have to worry about interlacing reducing the clarity of text. Games might not look that great though (unless you are farther than 8 feet back) and you will probably notice aliasing problems more. Although burn-in is overrated on CRT and plasma displays you will definitely need to take precautions to prevent it.
I've seen plasma's used on PC displays many times, with both DVI and VGA inputs. Will have to say that if you can run it at it's default resolution (853x480) it will look perfect- barring any aliasing effect from having absolutely huge pixels. Just hook it up right and enjoy- it will look fine for what you want to do with it (given the obvious limitations).
thanks for all your comments, i really appreciate the last guys comment and yeah i know plasma's don't last long, mabey sicne its on a pc I can have it turn off the monitor if my pc is idle for like 15 minuts that way it aint going down the toilet for nuthing. One more thing, i don't think there is any video card that supports that native resolution and the card I'm looking at is a AIW 9000 and thats 800x600 closest thing to that plasma
You can use a utility called Power Strip to create custom resolutions if your video card doesn't do the rez you are after.
That would be an ED display, be careful using DVI...you can break the set if you miss the res by too much. If you look NEC etc all reccomend against using DVI with a PC. That set will take a 1080i or 720p signal and down convert it to 480i.
Plasma has about the lifespan of a tube tv..5 or so years and it's much dimmer then it was when you bought it. If you don't compare to a new one you probably won't see it.
Small warning. MOST companies do not support online sales of their TV products. (flame me if you must, but I've been selling this stuff for 35 years). I find it strange that the sets I sell almost always never have a dead pixel. I find it more strange when people call for service about their "online purchase" with 6 to 8 dead pixels. Most warr papers state that 8 in one area is not a warranty matter. It's within tollerance.
You didn't see this so much 10 years ago but now most manufactures will not throw the questionable sets away, they sell them out the back door...then let the schlockers bring them in through Canada and Mexico. Grey market. Had two Sony XBR sets in last week, one with 7 pixels out one with 8. Both bought on line..Sony's comment? Tell the customer to send them back to the dealer..but they are within tollerance.
In over 10 years I've had like 2 sets with problems, all replaced my the manufacture.
Just my 2 cents.
BillR
I would vote for something like a Panasonic PT-L500U or PT-AE500U or a Sanyo Z2 projector. Both have a 1280x720 native resolution and you could get a HUGE picture out of them. Both retail for around $2000, so you'd be able to fit a nice screen and maybe even an extra bulb in your budget. Just a thought...
take a look at the Viewsonic N3020W
its lcd hdtv and only 30" but looks to be ok... i have only seen one review they did on the N3000W wich is almost exactly the same thing and they liked it alot.
ATI makes a component adapter for there newer cards. You can output using that to get a good picture on the screen.
Why pay $3k for a non-hd plasma when the panny 42" HD plasma can be found for that price when on sale?? EDTV is not the way to go man. As a matter of fact plasma is not that great of a solution (I've owned plasma,lcd, rptv, fptv) . Plasma screens will burn out after 3 years or so of use. If I were you I'd consider a front projector such as a BENQ FP8700 or the Sony Grand Wega III LCD screen (hands down best PQ on any television out of the box).
You do realize that you're having to interpolate 1080i and 720p to something that your plasma can handle? Rear projection/DLP/CRT are all gong to blow the plasma out of the water by being able to display true 1080i or 720p. Maybe DVDs...maybe digital cable...as the source material isn't all that good to start off with...
but an HD signal will not look anywhere near as good on that plasma. You are going to have to spend big bucks to get a plasma that will do justice to an HDTV signal.
