- 400MHZ for [H]
MTXR
Well, it looks like my box is just not stable anymore at 3.2
It was running for 3 weeks straight at 3.2@100% and not stable anymore. Probably power problem, but i have tried to take as many drives off the main powersupply and i still get random lockups. So for now, i am not going to be messing with my RAM VOLTAGE until a later date to see if this fixes stability @3.2.
So now the computer is at 2 x Xeons @ 3.0
How much production have i lost from the degrade in speed?(Average)
Sorry to hear about the loss of Hz. But, on the other hand, its only a drop of 6.25% per CPU or 9.1% overall. So I'd expect it to turn in work units just a bit slower. Nothing major.
Try cleaning up the HSFs? Or replacing the thermal compound? A few degrees can make a world of difference.
Tagan 480W.
I run Watercooling, so no HSF.
I think i need one of those sparkle/fortron PSU with 36A on the 12V rail.
Thing is though, only my 9800 pro, mobo, cpu, and raptor are on the tagan 480 and i have an enermax 432 running everything else, and i am still not stable anymore at 3.2.
MTXR said:
Tagan 480W.
thermal compound?
I am using AS5 on waterblocksm AS3 on NB, Cremique on VRM heatsink.
I doubt my temps are the reason for the lockup, i am at 41C on both cpus at 100% load.
hmm...
at that speed does it pass memtest?
hmm... i never really tried memtest, because it passed 4 instances of prime95 for 24+hours.
ANd i am not running my ram out of spec.
it was at 16x200 now its 15x200 so i dunno why my ram would mess up. It never had mem errors before... Running kingston ECC ram here.
But it could be a small drop in mem voltage, but i don't have a meter to measure so i can't mess with that yet.
my computer passed prime95 fine; didn't pass memetest.
changed ram = stability++
unlocked downwards.
Mine is 16-12
I have Xeon Prestonia core D1 Stepping, 400FSB @ 800FSB
Thing is though, its rock solid at 3.0 and was stable at 3.2 so it leaves me to believe something might be failing.
MTXR said:
unlocked downwards.
Mine is 16-12
Let's hope not... :(
Well, i just did a little more research and it looks like my ram wants 2.6V and PC-DL supplies only like 2.5V
So i have to do that crazy Vdimm mod. But i have no volt meter, so i won't be attempting it anytime soon.
So i guess 3.0 is hear to stay till i can find someone to borrow a volt meter. I think my undervolting of the ram at the higher speed is making it unstable.
Yeah, 2.6v is the JEDEC recommended voltage for PC3200. Can you at all run a memory divider on that?
you can probably get a fairly cheap volt meter at radioshack....
could you just loosen timings on the memory? that might do it.
My memory is as loose as you can get.
3-3-3-8
I am running ECC memory :-/
I'll take a look at radio shack. Pretty broke though.
