4000+ 2.6, high temps?
firebyyrd
I'm using a newly installed freezer pro 64, on my 4000+, and it's overclocked at around 2.65ghz.
It's running at idle 30C, and loads at 53C..
do you think these are good temps? I'm not sure, because I've seen lower on other computers.. could someone verify? Thanks.. I don't know if I need a reapplication, but it was a hassle getting the heatsink on it. =/
Those temps are better then what I had when I used the stock HSF w/no OC
idle temp is fine.. load is a bit higher than i'm used to for an idle that is that low. how is airflow in the case?
so right now at 2.7ghz,
I am running the max heat test, prime95.
the load temps are CPU:55C, and I'm using Coretemp, which read 50C load.
Which to believe?? Can I overclock some more? or should I stop here.
