4 x Vertex 30GB MLC ?
ledskof
I want to increase my drive performance in Vista64 so I'm looking at getting 4 x Vertex 30GB MLCs and 2 x Athena Dual 2.5" trays.
Can anyone recommend a hardware raid card that supports 4 drives that could push this? I really don't want to do this through a soft raid driver.
I know this is getting pricey so I'm still looking at performance numbers on whether this is really the route to go. That's $600 just for the drives. $72 for the trays. And I'm guessing $450 minimum on the RAID card, but I'm still looking.
Running Raid 0 is not really a performance bottleneck at the controller so much. For instance, I am running 4 X 30 gig OCZ Solid drives through a Dell Per 5i controller. That particular controller caps at a bit less than 400 MB/sec. The ICH10R controller built into a lot of MOBOs can run RAID 0 at close to 600 MB/sec. To get a stand alone controller that can do more than 600 MB/sec will cost quite a bit. Stand alone controllers are more important for funning Raid 5 due to the CRC calculations required.
If I were to set this system up again, I would prolly do the 4 drives in RAID 5, since I already have a good stand alone controller anyway. I would prolly still be capping the controller, but have a more reliable system.
4 X Vertex. Nice. :D
Don
Cool so you don't think it is really an issue just doing a soft RAID 0?
What about compared to just letting Vista handle it as a RAID volume with Vista's tools?
If Vista wouldn't suck at it, I could just get 2 decent controller cards and keep it from bottle necking to 1 card.
Well, if it is going to be your OS drive, then you need to have a bootable controller run the RAID. I don't run Raided data volumes, other than my NAS, so I don't know how Windows would be for that, other than I would not do it that way.
If your MOBO has a Matrix controller on board, unless you have a pressing need to go faster than 600 MB/sec, then you are good. If it has some other type of RAID, then you will need to do a little research to see what the throughput for RAID 0 is.
Even my slowpokie Perc 5i is blazing fast compared to magnetic drives. I just went with the Perc because it was relatively cheap, and has 256 meg of cache to help with the writes to my slowpokie Jmicron based SSDs.
Don
