I was trying to help a guy out that has a pretty weak rig, and is only running 1 gig with Vista 32, so I suggested he upgrade to 2 gigs (all his MB will allow) and just for the hell of it put in a 2 gig thumb drive until his memory gets ordered.
I have seen reviews where Vista does run more smoothly with Ready Boost when there is very little DDR memory, and it doesn't really help any when you have plenty of memeory all ready, like I do with 4 gigs.
Well, I decided to put my 2 gig USB in just for the hell of it and see what would happen.
My computer normally uses about 1300MB of ram (1.3 gigs) at idle. So I plug in my thumb drive, which is 2 gigs and about half full of my documents, and so I use 1 gig for ready boost. Look over at my memory monitor, and now my computer is only using 935MB of memory.
So the question is what is actually going on? Is it using the memory off the thumb drive, so it is no longer being used from the DDR2, is it reporting wrong, or is it just choking. I have had to run my rig with only 2 gigs before, and Vista is good at cutting itself back depending on how much memeory you have, so it was using about that 930 before when I had only 2 gigs in.
Any help here guys? Should I leave it in? Would it be worth the time to download some benchmarks (I don't have any at the moment), or do you have some answers.
