4 Dimm's in Asus A8N-E Mboard
Sorry, I posted previously and made a mistake in the motherboard model. It has been a long day, but I did catch it. I am running the 939 platform with the nforce4. I am currently having issues populating all four of my dimm slots. I am getting BSOD's and etc. I have tested the ram individually to make sure there is nothign wrong in that aspect. I only have the problems when all four dimm slots are populated. Any ideas? I have tried the 2T command rating, and for some reason when I put the ram settings to auto, it will run at 333mhz. I will have to check the manual and see if there is a reason for this.
Haha I ended up running memtest86 on the new memory rather than prime and found it to me completely errored, 6000+ when I turned it off after the first 2 mins. I just wanted to thank everyone that posted or read my post. BTW the memory was OCZ PC3200 Platinum 2-3-2-5, 1GB Dual Channel Kit. So watch out! How often does bad memory actually end up in the hands of the consumer? Especially OCZ I thought they had a rather good track record... I have done fine with them in the past.
