SoldierJAW
- Mar 13, 2012
Hello,
I was hoping that I could get some feedback on my current setup for overclocking my 3930K to 4.5 GHz for daily use (VMware, Gamining, and regular web browsing).
This is my first attempt at overclocking.
Setup:
Case: Corsair 650D (stock front fan, stock rear fan, both set to high on the case controller)
Cooler: Corsair H100 (stock fans, pulling in cold air, set to medium speed)
Motherboard: ASUS Rampage IV Formula (BIOS Version 1005)
RAM: G.SKILL F3-17000CL9Q-16GBZH Ripjawz PC3-17000 16GB 4X4GB DDR3-2133 CL9-11-10-28 1.65V (2133 MHz enabled with X.M.P Enabled as per https://docs.google.com/document/pub?id=17VKzOB5CL5EtIelw5tGsj2CqjBk3O0OU5VPe6CUoFso&pli=1)
CPU: Intel Core i7-3930K C2 (Overclocked to 4.5GHz) - Using the stock Thermal Interface Material (TIM) from the H100 (all screws are as tight as I can make them)
Video Card: EVGA GeForce GTX 580 3GB
Hard Drive: Western Digital Caviar Black 2TB 64MB Cache 7200RPM
Operating System: Windows 7 Ultimate SP1 64-Bit
Temperatures and VCore
Temperatures (in degrees Celsius) are reported using Real Temp GT 3.70 (Core Temp and CPUID read the same)
Idle:
Idle Temperatures: 40-33-26-35-33-32
Asus Probe II 31
Motherboard 33
Idle VCore (in CPU-Z): 0.816V
Load:
Load Temperatures: 78-71-65-70-73-74
Asus Probe II 70
Motherboard 33
Load VCore (in CPU-Z): 1.336V, 1.344V, and 1.352V
BIOS Settings:
Also, I like the power saving features of SpeedStep, and thus why I have it on.
I would like to keep it this computer for about 5 years.
I had heard that changing the CPU Strap could lead to lower voltages, but when I changed the CPU Strap to 125, and the BCLK Frequency to 125, it changed my RAM speed to above 2133 (something like 2333) and I had no option to select 2133 any more (until I lowered the BCLK Frequency), and the computer would not boot.
I would like any input and feedback that I can get. If you think I should change some settings, or if I should overclock it more, or anything else, please let me know!
I had to set the CPU Load-line Calibration to high from medium (is that safe for 24/7 use?), or else it would fail in LinX (it must need the higher voltage).
I would like to keep the temperatures down, but I am not sure how to get lower voltages that are stable.
Thanks!
Setup:
Idle:
Asus Probe II 31
Motherboard 33
Load:
Asus Probe II 70
Motherboard 33
BIOS Settings:
Thanks!
