4:3 in 2012, useless?
41U5253
So I need a lot of vertical space and I was thinking, well 4:3 monitor or 3 would fit that perfectly.
But then I remembered you could flip U2412Ms vertically, so 3 of them would be a nice fit with tons of width and height.
So what would be the best set up for me?
I run three 17" Dells at work at its fine for me since the company won't buy me widescreens. If you can get 3 2412, get them. You'll be happy with the setup.
If you need a lot of vertical space a widescreen monitor in portrait would be ideal. A 4:3 monitor (non-CRT) won't give you any more vertical pixels than 1920x1200 in landscape.
I run 3 24" monitors in portrait mode. It gives me 3600x1920 resolution. You can fit a full "legal" size paper in the screen without scrolling.
I concur that three 1920x1200 monitors in portrait is very ideal. The only thing that sucks about it are videos. But then you could just rotate one when you need to.
