- Jun 19, 2003
http://www.xbitlabs.com/articles/other/display/vapochill_11.html
Intersting benchmarks indeed
DASHlT
DASHlT
Originally posted by PliotronX
Yes interesting, but they forgot to mention that shortly after the benchmark suite with Prescott was completed, the caps and mosfets on the motherboard performed what appeared to be an explosion in the form of a small mushroom cloud, approximately 5ft. tall![]()
Originally posted by xonik
Wow, the Prescott didn't seem to gain a lead over the Northwood like Anand thought would happen at 3.6 GHz. The results seemed proportionally similar at 4.2 GHz as they did at 3.2 GHz. Pretty disappointing if you ask me...
Originally posted by pakotlar
yes and in other news, Anand likes to spew FUD.
Originally posted by Kirkov
very sad for precott
i feel bad for people "upgrading" or should I say downgrading![]()
Originally posted by EnderW
Does anyone think the new socket will change anything?
why is that unbelievable?Originally posted by Bigjohns97
did anyone else notice the unbelievable unbuffered memory benchmarks??
The leakage is at the transistor level. A new physical interface won't decrease current leakage in any capacity. The socket is for increased current handling, made necessary by increased current draw.
No, that's totally wrong. The leakage happens because at 90 nanometers, the transistors are so close together that the dielectric material separating them becomes less effective at isolating the flow of charge through transistors. Since the Prescott and other future 90 nanometer processors will feature more transistors, more closely spaced, the problem of current leakage will intensify unless improved dielectric solutions like silicon-on-insulator or a low-k germanium or silicon is used.Originally posted by chrisf6969
Yes, but if the current can be supplied closer to where it is needed it will not have to travel across as many transistors. So few transistors to travel over = less leakage.
