$4 120mm Panaflo M1A
BG Micro has 4 dollar M1a Panaflos. These aren't the extremely quiet panaflos. Nor are these the loudest pananflos. These are ~86CFm and 35 dB. Shipping is a not included, but i got 4 for less than 15 bucks shipped I think. http://bgmicro.com/lmad.asp
i got one of these from bgmicro a few months ago. they are pretty loud at stock so you might want to undervolt them to 7v.. thats a perfect mixture between performance and silence.
I bought three of these several months ago. They are not quiet, even when undervolted. They emit a very noticeable ticking which is unbelieveably annoying. I wouldn't touch these unless you're planning to use tham at full speed.
Is it just the 4 dollar panaflows from this website, or all in general?
Its odd what you are saying about htem being very loud... These have the Hydra Wave bearings in them and are supposed to be very quiet for the amount of air they move and the rpm they spin at.
funny, I currently have 2 of them on my radiator and find them to be pretty quite. They are no louder than my enermax PSU....
thanks for the link, picked up 3 more of them...
wonder if they are going to charge me shipping...
James Binkley, thank you very much for your order.
Date / Time of your order: 12/10/2004 5:52:03 AM
Your order consists of:
(3) FAN1080 - 120mm Panaflo Fan $11.97
Subtotal: $11.97
Tax: $0.00
Total: $11.97
Thank you for shopping with B.G. Micro!
The exact model of fan this website is selling. Not in general.
I never said they were very loud. When undervolted, they are pretty darn quiet, but there is a noticible ticking sound (not exactly ticking -- it's more of a rapid-fire groaning) which is louder than the spinning blades and air movement at around 5v-7v.
As long as you keep the fan speed high enough to drown out this groaning noise, they are fine. I mean.. they're $4. Great if you don't mind the semi-moderate noise.
lol.. I bet most people can live with semi moderate noise. If you are much more picky than that I'd say you got issues. My computer is drowned out by the noise coming in from outside , but I live in a city and keep my window open.
I bought mine because my other 120mm's ticked at 5v, this one just makes air sounds ( insert blonde) and is very quiet. They are also huge, like 38mm deep. Maybe theres jap ones and ty ones like the 80mm l1a's?
12 volt heavy duty solar charger. Made for the outdoors. Water proof, rust proof, corrosion proof, and UV protected. This 12V/70mA Solar cell is designed for use in deer feeders, boats, farm tractors, fence chargers, or any number of other applications. Power your robot from the sun. No load voltage: 18V. Panel measures 6-7/8"x6-1/4"x11/16".
PWR1199.................................$26.50
WHy does one want there solar pannel uv protective? Doesnt that defeat the perpose?
nightanole said:
WHy does one want there solar pannel uv protective? Doesnt that defeat the purpose?
The plastic used in solar panels breaks down under uv light, so you filter the worst out.
Re: the Panaflo M1As, I'm using 3 of these on a radiator and they are easily the best fans I've ever used. All 3 wired together, running thru a Sunbeam Rheobus, there is certainly an 'engine whine' above the rush of air, but it is not so pronounced as to be irritating, even at fullspeed. The Rheobus goes from 0-12v, and at lower settings (which other fans I've tried would stall at) the Panaflos blend into room noise very well.
I'm extremely pleased with these fans. If you want *case* fans, or are adamant about dB levels, just get the L1A model, which bgmicro also sells I believe.
rms
cgrant26 said:
Rheobus or in-line resister.
If you're into doing things the hard/expensive way. I think if I do anything to undervolt them it will be a simple 7 volt mod on the 3 pin/4pin adapters I'm gonna plug these into.
what is everyone's thought about the high output version compared to the medium? also if anybody could tell me how these 2 different models sound like compared to other real world things, i would really appreciate it. ex: lawnmower...
bein quiet is all relative .. everybody has diff standards of course ;) 4 bux for'em i think is an awesome deal.. but the antec and nexus fans are way better than these in my opinion.. even w/ hydrowave bearing, these can't compare to the smaller 80mm fans on sound (by that i mean they click like a bitch). But of course.. they now make the 80mm ones in china.. and i can hear a definate difference in the older japan made ones and newer china made ones (80mm i mean) ..
u can read all about this quiet stuff on www.silentpcreview.com .. it's for hardcore ppl on silent comps tho :D .. i for one .. think my revision a4 seasonic 400 watt tornado psu is pretty damn loud.. but 99% of the ppl i know thikn seasonic psus are very quiet :D. and no, my seasonic psu isn't defective.
Ticking and rapid-fire groaning. I've heard a lot of fans in my time, and none of them sounded like that!
I take it you have never had a pwm fan speed controller before:) I for one never heard it with a standard 7v/5v mod, just with the speed controls.
Guess you don't own one of these fans yet, eh? .....
Well, for any of you obsessed with near-silent cooling... it's not cheap, but here's a 14dBa 120mm fan for $24. Anywho, I'd just do a 7-volt mod on the Panaflos, or even a 5-volt mod and get it quiet that way. Just take it for what it's worth...
-SEAL
i ordered 3 of the fans on Friday.They didnt charge me shipping and they arrived today via priority mail...woohoo. Great deal, thanks for the link, time to bust out the dremmel tonight.
