morpheus9394
- May 8, 2002
Prior to the 4.1 coming out I was using 3.10 on my AMD system with my 9800pro and had no problems running the Far Cry demo, though it was a little slow on max details but that was due to my PC not being up to the task.
I have since upgraded to a p4 2.8ghz with 1ghz corsair ram etc etc, and I decided to go straight to the 4.1 drivers.
All my games work fine, Call of Duty, Need for Speed Underground etc, as does all my benchmarking software, 3dmark 2001/3, Aquamark3 but Far Cry now does not run.
You can boot get into the main menu ok, but when you try to start the game, it loads and it will either lock the PC or you get sound but no display.
Has anyone has had similar problems? I am trying to figure out with it is my PC being unstable (as I am overclocking the video card and pushing the ram quite hard) or whether it is just the game (which I suspect to be the case)
I run 3dmark 2003 in looping mode for 8hrs with no crashes so my PC seems ok.
