4.1 cat question
BigMaxxin
is the temp monitor in there acurate or is it based on some math problem wheree it only works if the overdrive is on? if it is an accurate temp gauge is 38C a good temp for running it at 570/660? BTW: this is on a 9600XT
from what I've seen ...the 9600xt temp gauge is pretty accurate, but the 9800xt gauge reads high of upwards of 20c
my 9800xt says 63c for a temp , tho I'm on air, I have 13 case fans getting good air flowage thru case ..so I'm sure that has to be high
im on air cool as well. i have f fans at the front of my case, one exhaust, but i do have an exhaust blower right above my card right on the ram sinks, so i think that helps, but thats good to know.
