3x80mm fan radiator??
cell_491
does anyone know where i can find a radiator that is made for 3x80mm fans (2x120mm is too wide for my application)
Never seen any specifically for PC watercooling; best bet would probably be to head to an autoparts store with some measurements and start checking out heatercores. Geo metro anyone? :D
Where are you planning on putting it?
cell_491: Take a look at this link and browse to the heatercore section. There is a link under that section that you can download a decent heatercore excel spreadsheet. You might be able to find a heatercore that will fit your needs
Watercooling: The basics
-bn
again take a look at that link. But a common single 120 would be a chevette heater core. If your looking for a prefab radiator any water cooling shop should have them.
cell_491 said:
does anyone know of a good single 120mm radiator?
Probably the best deal out there right now is either the BI Pro from Danger Den or a similar product from Cooling Works. With the drop in prices of commercial computer radiators the only reason IMHO to do a heater core is if you think it will work better in your loop. :)
sweet action..thats the same as the black ice extreme but it has interchangable fittings and its half the price!! In your oppinion whats the best fan to pair that with? I need some with decent flow rate but it needs to be very quiet
Well I don't have any experience with heater cores, but it seems a tad high considering the cost of the BI Pro's now. The fans I am using are extremely silent, but they are expensive! They are made by a company called Acoustifan and seem to put out more air than the Papst even at 5 volts. You can get them from Sharka.
