Has anyone been able to find a 3x3 (450mbps) WiFi antenna for the 802.11n 5GHz band? I'm pretty much looking for something similar to this, which works at 2.4GHz:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833998060
I've done a considerable amount of searching and have not been able to come up with anything. Individual 5GHz dipole antennas can be bought online, but these would be a sub-optimal solution for me, as I would like the antenna to have a solid base so it can sit on the desk/bookshelf.
Edit: Found a Proxim antenna that claims to be dual-band, but it's pricey. Also claims to use reverse SMA connectors, so should work with desktop WiFi cards or mini PCIe cards with pigtails.
http://www.cdw.com/shop/products/Proxim-3x3-MIMO-Range-Extender-Antenna-antenna/2144382.aspx
Anyone familiar with other options?
