3x2GB DDR3 recommendations
BeavermanA
Finally ordered an i7 920 to replace my aging e6600.
What are some of the best bang for buck 6GB kits for an X58 board? More specifically the GA-X58A-UD7 from Gigabyte which is my top pick currently. I don't want budget , nor extreme priced kits. Plan to have my 920 run around 4.0ghz or a bit higher.
I haven't looked at memory since 2007, so if you can narrow down my choices I would appreciate it. So what would you buy if you were running this setup, lets say with $250, plus or minus $50?
I just ordered this kit
https://www.linkecomputer.com/products/200049/F3-10666CL9T-6GBNQ/G.SKILL/
It's the G.skill 3x2gb DDR3-1600 kit that comes very highly recommended on these forums.
Never ordered from the above retailer before, but I've found a few people who've had a positive experience from them, and the price was definitely right! It's shipping from Hong Kong, so between 1-2 weeks for delivery, I'm not in a rush so this was fine with me.
*EDIT* the above sale is off, it's no longer $149, it's now the same price as newegg
Alternatively, the same kit from newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225&cm_re=g.skill_6gb-_-20-231-225-_-Product
G.skill makes great ram, been using them for years now.
If you want a good mid tiered memory, they one to go with is:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
It's corsair's dominator 1600. If you do some research, you'll see it places top to near top in every review, and is an 8x customer choice winner with 5 star reviews for good reason.
When I built my i7 build, I went with a cheaper g skill ram set (mostly because at the time, it was pretty expensive). It stopped me from quite getting to 4.0, and the ram was the hold out. I ended up getting the corsair ram a few months later and getting to 4.2 eventually. It was worth the expense.
That Corsair kit is too expensive for many, and I don't really think the price premium is justified unless you're going to be benching a lot. In reality, it places near the top in every review in synthetic benchmarks, but there is very little (if any) difference in real-world performance. Thus, I recommend the G.Skill that I linked to above. Not to mention that the lower voltage provides additional headroom when overclocking.
Well thx for the advice, but I worked 16.5 hrs of overtime this week so said screw it and got some 6GB Corsair Dominator GT's 1866mhz. Fell within my range with 15% cashback. Think they will look good with the Rampage III extreme board when it's released. Ever since I got this 800D case, I have become obsessed with how my rig looks lol.
Well TigerDirect had it last night, I find myself checking almost every day out of habit because I don't get taxed there like at newegg plus it's free shipping. Has been at 8% or less for a while I believe, and now it's back to 8.3% with all the search terms I try.
Nice, I hear you on the newegg tax, I've been doing the same, shame I missed the 15% =/
I'll think you'll find the investment in solid ram worth it, Beaverman. I'd love to hear how the ram works for you - I had thought about purchasing that same kit myself.
Just to note, PC User - I was paying attention to the original post, which suggested a $200-300 (250+-$50) spending range, so I knew my recommendation wasn't outside this particular spending range. I wasn't negating anyone's suggestion - G skill makes fine ram - just saying that in my experience (owning both G skill and corsair's RAM), I recommended the corsair kit.
Yea well hopefully they work better this time. I've always gone with Corsair initially, this current rig at first had the CL4 DDR2 800mhz 2x1GB Corsair Dominator kit, but I freakin bought my budget mobo, the Asus P5N-E SLI the week it came out I think, only to find out it had serious issues with overclocking the memory kit. Was only ever able to get them to a laughable 830mhz at 4-4-4-12 2T. I guess they finally made a BIOS that makes them work better, but by that time I had tried this $20 4GB Crucial kit when ram was dirt cheap.
