Currently have 9550sx-12 raid card on my server. I'm wondering what i'm missing to get maximum performance out of it. Its currently setup with raid 50 with 6 total drives. Here is a post of my speed test:
My question is that my read speed per request basically appears to be around 70mb for example if i use a program that examins a file it will max out around 70mb /sec. I can open this with 3 sessions running scanning 3 files and it will do them each at about 70mb /sec. Basically 210mb read speed... The same thing happens when I write to the array. I try to write from a raid 0 array to this raid 50 array and it tops out at 70-80 but i write from 3 sperate disk to the raid 50 array and it will do them each at 70mb/sec. Is there some sort of setting that limits each write or read action? Specs posted below of server. Is there some sort of setting in windows that limits write/read speed of arrays because thats what it seems like to me. My overall speed can do writes/reads of 200+mb. Let me know what you think
Windows 7 64bit
3WARE 9550SX-12 raid 50
6x wd green drives
SUPERMICRO MBD-X7SBE
Q6600 CPU
4gb ram
Windows 7 64bit
6x wd green drives
Q6600 CPU
4gb ram
