Turbosound
- Sep 10, 2011
I just purchased a WD cavair green 3TB internal drive to use as a secondary drive for my MKV video files. However after in installed windows 7x64 on my primary drive, As soon as I opened disc management it promted me to initialize the 3TB using MBR or GPT. I selected GPT but the drive is showing up as 746.39GB!
I'm aware that drives larger than 2TB require the GPT partition style and if you want to boot from a drive that is larger than 2TB your motherboard must support UEFI. My motherboard does not support UEFI and was told by WD that I would have no issues using a 3TB drive as a secondary drive using windows 7x64, prior to my purchase.
What exactly is the issue?
I haven't establihed an internet connection yet, and have a lot of windows updates to download/install, can one of the windows updates fix the problem?
I heard that downloading the Intel rapid storage technoligy drivers may fix the problem, are there any other options?
I have a Nforce 650 SLI chipset and my pc is a Dell XPS630i, and therfore dont know if the Intels RST drivers would apply to me.
Thanks
Thanks
