What do you think is the best air and budget water cooling solution for this card.
I have never taken the HSF off a Gcard before. I am not even sure if removing it and applying AS5 would be worth it or not. Regardless I am just looking for some ideas
or direction in regards to modded cooling of this card. I would like to obtain a decent overclock with this card with reasonable temperatures.
I have actually seen a small water cooling package specifically designed for G cards. I believe it is made by Coolermaster and is called Aqua Viva. I assumed this setup was pretty hoaky because I haven't seen and reviews and its pretty cheap.
So air and water alternatives?
Cheers
Cheers
