3rd HD problem
FrostFox
ok heres my problem
i have 2 new sata drives 1raptor 36gb and 1 wd caviar special ed 200gb.
2 new sata drives are ntfs
old ide drive is FAT32
i am tryin to gain access to an old ide hd,(OLD HD IS STORAGE ONLY NO OS ON IT)
when i boot xp with the 3rd hd connected xp see's it but wont allocate it a drive letter, in disk management i only have option to delete partition all other options are greyed out. but it shows the drive as healthy and active
now when i was installin xp with the 3rd hd connected xp would not allow install on any of the sata drives saying the drive did not contain a winxp partition, but with the 3rd hd disconnected no problems.
when i use command prompt through the xp cd(xp restorer or something like that) it sees drives c,d,e all 3, when i DIR on my old drive everything is there.
could i use the command prompt COPY function and if i can how would i copy everything or copy individual folders?
Actually you want to use "xcopy" to move whole directories and directory structures. I back up my stuff to a second internal hard drive. It used to take a boatload of CD's or even DVD's, but I have a little batch file that I can fire off when I'm not at the PC and it takes care of the job. I figure the only way I can lose data is if I have two drives die at the same time....not likely, I think. Here's the command line I use:
xcopy "C:\whatever" "Z:\backup\C Drive\whatever" /E /H /I /R /Y
....I'm still fiddling with it a little, but it seems to copy every directory and file underneath the root (In this case - "whatever") to the target drive just fine. You'll need one of these command lines for every directory you want to back up / copy. I have them in a little batch file that runs like the bomb I suppose you could do a whole drive, If you wanted to, with this same command line.
Good Luck - B.B.S.
XP has robocopy built in which can automatically transverse subdirectories..
Type Robocopy /? at the command prompt for a full list of switches.
....never heard of "robocopy"....??
Sorry, my mistake, its part of the XP resource kit. Its like xcopy but has more options and capabilites than xcopy.
C:\Program Files\Windows Resource Kits\Tools>robocopy /?
ROBOCOPY :: Robust File Copy for Windows :: Version XP010
Started : Sat Jun 12 13:30:15 2004
Usage :: ROBOCOPY source destination [file [file]...] [options]
source :: Source Directory (drive:\path or \\server\share\path).
destination :: Destination Dir (drive:\path or \\server\share\path).
file :: File(s) to copy (names/wildcards: default is "*.*").
:: Copy options :
/S :: copy Subdirectories, but not empty ones.
/E :: copy subdirectories, including Empty ones.
/LEV:n :: only copy the top n LEVels of the source directory tree.
/Z :: copy files in restartable mode.
/B :: copy files in Backup mode.
/ZB :: use restartable mode; if access denied use Backup mode.
/COPY:copyflag :: what to COPY (default is /COPY:DAT).
(copyflags : D=Data, A=Attributes, T=Timestamps).
(S=Security=NTFS ACLs, O=Owner info, U=aUditing info).
/SEC :: copy files with SECurity (equivalent to /COPY:DATS).
/COPYALL :: COPY ALL file info (equivalent to /COPY:DATSOU).
/NOCOPY :: COPY NO file info (useful with /PURGE).
/PURGE :: delete dest files/dirs that no longer exist in source.
/MIR :: MIRror a directory tree (equivalent to /E plus /PURGE).
/MOV :: MOVe files (delete from source after copying).
/MOVE :: MOVE files AND dirs (delete from source after copying).
/A+:[RASHNT] :: add the given Attributes to copied files.
/A-:[RASHNT] :: remove the given Attributes from copied files.
/CREATE :: CREATE directory tree and zero-length files only.
/FAT :: create destination files using 8.3 FAT file names only.
/FFT :: assume FAT File Times (2-second granularity).
/256 :: turn off very long path (> 256 characters) support.
/MON:n :: MONitor source; run again when more than n changes seen.
/MOT:m :: MOnitor source; run again in m minutes Time, if changed.
/RH:hhmm-hhmm :: Run Hours - times when new copies may be started.
/PF :: check run hours on a Per File (not per pass) basis.
/IPG:n :: Inter-Packet Gap (ms), to free bandwidth on slow lines.
:: File Selection Options :
/A :: copy only files with the Archive attribute set.
/M :: copy only files with the Archive attribute and reset it.
/IA:[RASHCNETO] :: Include only files with any of the given Attributes set.
/XA:[RASHCNETO] :: eXclude files with any of the given Attributes set.
/XF file [file]... :: eXclude Files matching given names/paths/wildcards.
/XD dirs [dirs]... :: eXclude Directories matching given names/paths.
/XC :: eXclude Changed files.
/XN :: eXclude Newer files.
/XO :: eXclude Older files.
/XX :: eXclude eXtra files and directories.
/XL :: eXclude Lonely files and directories.
/IS :: Include Same files.
/IT :: Include Tweaked files.
/MAX:n :: MAXimum file size - exclude files bigger than n bytes.
/MIN:n :: MINimum file size - exclude files smaller than n bytes.
/MAXAGE:n :: MAXimum file AGE - exclude files older than n days/date.
/MINAGE:n :: MINimum file AGE - exclude files newer than n days/date.
/MAXLAD:n :: MAXimum Last Access Date - exclude files unused since n.
/MINLAD:n :: MINimum Last Access Date - exclude files used since n.
(If n < 1900 then n = n days, else n = YYYYMMDD date).
/XJ :: eXclude Junction points. (normally included by default).
:: Retry Options :
/R:n :: number of Retries on failed copies: default 1 million.
/W:n :: Wait time between retries: default is 30 seconds.
/REG :: Save /R:n and /W:n in the Registry as default settings.
/TBD :: wait for sharenames To Be Defined (retry error 67).
:: Logging Options :
/L :: List only - don't copy, timestamp or delete any files.
/X :: report all eXtra files, not just those selected.
/V :: produce Verbose output, showing skipped files.
/TS :: include source file Time Stamps in the output.
/FP :: include Full Pathname of files in the output.
/NS :: No Size - don't log file sizes.
/NC :: No Class - don't log file classes.
/NFL :: No File List - don't log file names.
/NDL :: No Directory List - don't log directory names.
/NP :: No Progress - don't display % copied.
/ETA :: show Estimated Time of Arrival of copied files.
/LOG:file :: output status to LOG file (overwrite existing log).
/LOG+:file :: output status to LOG file (append to existing log).
/TEE :: output to console window, as well as the log file.
/NJH :: No Job Header.
/NJS :: No Job Summary.
:: Job Options :
/JOB:jobname :: take parameters from the named JOB file.
/SAVE:jobname :: SAVE parameters to the named job file
/QUIT :: QUIT after processing command line (to view parameters).
/NOSD :: NO Source Directory is specified.
/NODD :: NO Destination Directory is specified.
/IF :: Include the following Files.
