Hello everyone,
I'm a bit confused about 3pin aftermarket cpu fan.
Does the fan rotate at a constant speed when plugged into a 4pin fan header ?
Or those the fan speed goes up as cpu temperature goes up ?
It is my understanding that a 4pin cpu fan does variate it's speed according to cpu temp.
Thanks for your response and Happy Holidays.
