3dmarks went down after changing from Nvidia to ATI????
EquaLiZr
Well before i had the 2x 7800GT's and now i have the 1950xtx and my 3dmarks are worse than before.
before i had 6489 and now i get 4877 :mad:
im still trying to understand the CCC control pannel. what should all the settings be at for 3dmark benching?
What Catalyst version are you using? Also CCC isn't all that great. there are other tools out there that are much cleaner and flexible.
running the 6.9's
i used driver cleaner to get rid of the nvidia stuff and ATI then re-installed the ATI drivers and have not installed ati tools or anything (yet)
I think sli 7800gt might be a tad faster than 1950 but I could be wrong...
You should just reformat since you seem to have lots of problems and see what it does for you..
well i benched my x1900xt 512 last night and got 4842.....
Crossfire/SLI Usually have better score than single card. I've seen people with SLI/Crossfire get twice the score they had when using single card.
Acording to this chart
x1950 XTX only have 10,400 fillrate while 2x 7800GT have 8,000*2 = 16,000 fillrate
You had SLI before - it's going to be higher in 3dmark.
My X1900XTX overclocked got me about 5000, then I changed to an overclocked dual core CPU and jumped to about 6000 (since my CPU score jumped). Now I'm using a 7950 GX2 OC'd to 600/800 and get 9200 with a 3 ghz X2 3800.
You score is about right, the SLI will score higher tho...
Yeah, as everyone already said, it seems right.
I think you were expecting too much of the X1950 XTX. You'll notice that some games will run better on the X1950 XTX, than on the 7800 GT SLI though.
k i guess i understand the 3dmark thingy but as for the games, they all run faster and at higher resolutions! I am super happy with this card and i guess 3dmark doesnt matter :)
I had this same problem after switching to ATi. The driver cleaner did not work for me, after reinstalling OS I got higher benches.
WIth my X190xtx stock and Opteron 175 I get 5994 3dmark06. Im running cat 6.3 cp version (the one listed for firemv cards). All other versions I have tried seem to be too choppy in games.
sry to brag but my 7950GX2 beats the 1950XTX ON MOST GAMES! looks like ati cant keep up? i could be wrong.
And that's relevant to this post how?
Not really related, and I doubt it beats most games by much if at all. The 7950gx2 is two cards in one...the 1950 is one card using gddr4 with higher clocks, yet still keeps up with lower power requirements(gddr4). Think how bad the 1950 would rape the 7950 if the 1950 was a 1950XF2 or something.
Give the guy some good news. He just got rid of two cards to buy one really expensive one that doesn't perform as well as the SLi.
1.) You'll get better image quality.
2.) You can always get an X1900 Crossfire and a crossfire board and blow away the 7800's in SLi...
Thats about it though.
3.) lower power consumption/requirements due the x1950 being the first card to use Gddr4.
It would most certainly have clock speeds far lower than the X1950 (650MHz), but such a thing would probably still pass the GX2 by.
well like i said i dont think i downgraded as i get better performance with the 1950xtx than i did with my 2x 7800gt's. I seriously get better performance with all games across the board and with higher settings now than i did before. i'll do a re-install if necessary
It is not really necessary, take 3dmark with 3 grains of salt.
